08-08-2013 08:08 AM
Hi
I want to create a custom device which will allow me to select channels from the system explorer. I found NI Veristand Add-on - Channel Select Dialog (http://zone.ni.com/devzone/cda/epd/p/id/6266) . That's exactly what i need. I downloaded this add on and tried to call the vi from the Main page of the custom device.
The first thing is this vi need NIVS.System Definition Root .To get this i wrote the code attached.
I don't thinkif it's really working cause when i call the channel_select_dialog.vi the treeview on which i am supposed to select the channel is empty.
So what is the good method to get the System definition Root ? Is it possible to call the channel_select_dialog.vi from a custom device ? or is it reserved to Custom Workspace Objects??
08-08-2013 09:19 PM
See the waveform custom device shipping example (in 2012). It has a channel selection dialog you can copy.
08-09-2013 02:19 AM
Hi Stephen
I downloaded the add on "Waveform Data Logger Custom Device" from here :
https://decibel.ni.com/content/docs/DOC-29957
Unfortunately the source code is not provided, and when i try to open the Main page from the llb, i can't access to the diagramm block. Any idea ?
08-09-2013 03:58 PM
At this time we have not decided to release the source code for that download.
instead, look at the shipping example I mentioned before
08-26-2013 05:13 AM
Hi stephen
Can you tell me where i can find this example, i didn't found any waveform custom device example in VS 2012... that's why i downloaded the Waveform data logger ...
Thanks...
08-26-2013 09:08 AM
It is here on my computer:
C:\Program Files (x86)\National Instruments\LabVIEW 2012\examples\NI Veristand\Custom Devices\Waveform Analysis and Generation
06-26-2017 02:18 AM
One input is required:
