07-12-2019 06:23 AM - edited 07-12-2019 06:34 AM
Dear Forum
my Veristand PXI fills the internal SSD with data which is unreadable until it crashes on start with the error messages DEAD_AF397F50 and DEAD_ADA6C370. Unfortunately it is not possible to debug it through the serial port because the necessary parameters can not be set in the ini file. The harddrive can not be accessed via ftp and I can't mount it on a windows PC because the partition is formatted with the reliance filesystem.
Any ideas? I am on the second 80GB SSD and killed a 320GB harddrive already with the same issue. Interestingly it only took a fraction of time to fill the larger harddrive than it did to fill the SSD. I am out of ideas and for now just keep two SSDs with copies of the system as replacements for the next time it dies.
Any input is greatly appreciated!
Raphael
07-24-2019 10:58 AM
Hello Raphael,
Both error codes seems completely unknown on any web search.
Could you give us more insight on what you are doing with your PXI?
How often does your SSD die?
Is the memory increase on the SSD continuous or does it happen all of a sudden?
M-Junior
