04-19-2018 10:31 AM
Solved! Go to Solution.
04-19-2018 10:37 AM
The screenshot you included is just a warning that when you format the device with a new file system, you will erase any existing data on the drive. Can you clarify what part of the formatting process isn't working?
04-19-2018 10:58 AM
04-19-2018 11:09 AM
Ah, I missed that. Is your hardware setup supported according to this list?
04-20-2018 03:32 AM
I tested my pc that pass all condition....
I can use safe mode to install software by USB boot(select 2)...
And I can usb boot select 1...All functions can work correct...
If I use this method...would be always boot from usb(select 1)..
I think the Pharlap not support SSD HD ???
04-20-2018 09:39 AM - edited 04-20-2018 09:40 AM
The SSD should not be a problem. For example, the PXIe 8880 has an SSD hard drive and can be purchased with Phar Lap.
04-20-2018 09:57 AM
so..Which step might be wrong?
or give me some advice....thx!!
04-20-2018 10:26 AM - edited 04-20-2018 10:27 AM
Hey hsinhsiang,
Have you tried typing "yes" instead of "y"? You may have a BIOS that does not accept "y" as "yes", so the utilities default to not formatting the hard drive. I found some internal documentation that pointed to this as a possible cause.
04-23-2018 08:44 PM
I make a fool of myself.....
It just types "yes" would be OK..
