VeriStand
Converting old VeriStand project
During NIDays last year I discussed uprading VeriStand setup from 2014 to a more modern version. The NI-representative mentioned that when upgrading from VS2014 to for example 2017, due to some incompatibilities, a project conversion tool might be necessary.
I have not seen this tool mentioned anywhere. Is it actually required? If yes - has anyone seen it?
Regards
(1,633 Views)
Accepted by Niklasson
I have converted a project from 2012 to 2019 just by opening the old project in the new verison of VeriStand and saving the project from there, this worked without issue
(1,628 Views)
also if you have custom devices or workspace objects these will be need to be rebuilt in LabView which is the same version as your new version of VeriStand
i.e. 2019 VeriStand needs LabView 2019 builds
(1,622 Views)
Yes, that makes sense. Thanks for the reply.
(1,598 Views)
no problem, mark my comment as the solution and the thread solved when this works for you 🙂
(1,595 Views)
