VeriStand
Compiling Simulink Models to Veristand Target
Hello, I am attempting add a Veristand target to my simulink code generator. There should be a corresponding .tlc file I can use, however, I've been unable to locate it anywhere in either installation or online.
Comments or requests for clarification welcome.
Thanks.
(2,656 Views)
Accepted by topic author johndoe_embedded
The .tlc file will be part of the VeriStand model framework which is a component in the VeriStand installation. Info on how to install that can be found here.
Additionally, you might also want to check version compatibility here.
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(2,641 Views)
