NI VeriStand
Calculated Channels - upload
I created a Calculated Channel (MyCalcChannel) and I used Condition like setting.
So MyCalcChannel is 0
if MyChannel is 0
   then MyCalcChannel is 1
   else MyCalcChannel is 0
and until now there aren't problems...
Now, In my my workspace, I have the MyChannel control and MyCalcChannel indicator. If I change the MyChannel value, the MyCalcChannel works properly, but If I change MyCalcChannel I supposed that the clock after it takes the rigth value, but it doesn't.
Why? I hope it is clear otherwise I'm going to send an example
Thank you Fabio
(550 Views)
I'm wondering how you managed to change the value of a Calculated Channel from the workspace? It should not be possible as all calculated channels are read only ...
CLA, CTA, CLED
(514 Views)
Thank you very much for your answer. In fact when I change the Calculated Channel Value I can read an error... So the effect that I can read is that the control/indicator change value but the channel value is the same...
I don't like very much this effect. If I define an object like an indicator the user cannot modify its value. But that is.
(507 Views)
