07-18-2017 12:30 AM
Hi Everyone,
I have some questions regarding VeriStand.I have plant model which is designed in LV.
Q.1-->Can you Explain me the things which we can't do in TestStand but can be done in VeriStand.
Because the plant model which we are creating in LV we can be tested using TestStand then why VeriStand is needed.
Q.2-->I'm Confused because the user interface for plant model which is built in LV, to test In VeriStand we have to create the User Interface again. Why it is needed to create the user interface again.
Q.3-->Approaching NI tools for testing the plant model.
Thank You!
07-18-2017 10:11 AM - edited 07-18-2017 10:21 AM
Please see this presentation for your question 1 and question 3:
https://www.youtube.com/watch?v=nQ6RGAyj_vk
It should answer the majority of your questions about the products.
For your question 2, a VI has the UI of the "model". However, if you try to "test" the model, then you will notice that the UI for testing can be bit different than the UI for modeling. But you should be able to reuse some components of the created VI UI in Veristand, if you desire. Unfortunately, depending of the functionality, you will need more "advanced" knowledge in VS to create those controls.
