08-07-2018 05:32 AM
I have a 9137 running Linux RT.
Can I use it with Veristand?
The documentation makes it clear that it will work with cRIO or PXI controllers but I am not 100% clear on RT cDAQ.
Many Thanks
Solved! Go to Solution.
08-07-2018 10:13 AM
Hi Nick. VeriStand does not support CompactDAQ controllers running Linux Real-Time. This is documented in the help in a few places, but it is a bit hard to find. This help page includes the note, "VeriStand is not supported on x64 Intel-based cDAQ controllers running NI Linux Real-Time."
08-07-2018 11:05 AM
Thats a bummer.
Whats the fundamental limitation here? Veristand does support NI Linux RT on other targets right?
Is support likely to be ever added?
Thanks so much
08-08-2018 10:31 AM
Good question, Nick. VeriStand is designed (and built on) single-point, closed-loop control. See this KB for a little more detail about this. The reason CompactDAQ controllers running Linux RT aren't supported in VeriStand is because these controllers do not support hardware-timed single point sample mode for any task type. See this document for a more complete list of devices that don't support hardware-timed single point acquisition.
Hopefully that clears things up!
08-08-2018 10:44 AM
Hi, yes this does clear things up. Obviously begs the question why RT cDAQ doesn't support HTSP... some internal architecture compromise I guess but I also guess this is beyond the scope of the Veristand board!
