04-03-2018 07:02 AM
Hello all,
I am currently playing around with the ASAM.XIL API to log directly from VeriStand to MDF4 and am stuck at the following points:
1.: Is there any way to give better names to the channel groups?
In the XML File that determines, which Tasks are present in the System, I can set the names to "TaskN" where N is the frequency. What I would like, is to name them "Temperature" at best, or at least "Temperature1" to get a good structure into those files.
2.: Is there a way to connect to the Model Access Port without getting having to start and deploy the project? My goal is to run the program I'm writing from a console step from the Stimulus Profile. Best Case, this would be done without interrupting project execution.
However, when I run the code from the Example, it throws an error, when the
maport.Configure
step executes and the project is already running. Is there a different way to connect?
Peter
04-03-2018 08:58 AM
Bonus Question:
I created a MaPortConfig Class to be able to serialize into the correct XML Format. Is there a class I could inherit from that already has the structure needed?
IMAPortConfig seems like the logical choice, but it looks pretty empty.
04-11-2018 08:56 AM
Per Veristand help:
"Format task names as follows: TaskN, where N is the frequency in Hz of the task."
To my understanding, this would mean answer "not possible" to your question #1.
This example here may be some hint to achieve your goal: The following example, written in C#, uses the ASAM XIL API to capture and save channel value data to an MDF4 file. This C# code references the Engine Demo example project.
Take care
04-11-2018 11:58 PM
I think the second link you posted is incorrect, can you please check again, so I can have a better look?
04-12-2018 01:38 AM
I double checked and link should work fine. In case if for any reason it doesn't for you, try to find "C# Walkthrough: Capturing and Logging Channel Values" via Google.
04-12-2018 03:08 AM
OK, thanks for checking again! It is, however, the link from my initial question.
I guess it is a "no" on that one as well.
04-12-2018 03:20 AM
The situation is, that this two things are mandated by the ASAM XIL standard/XIL group. So as we strictly follow that, you cannot f.e. change the state machine...
Recommended reading:
https://www.asam.net/standards/detail/xil/
https://www.asam.net/standards/detail/xil-ma/
~Jiri
CLA, CTA, CLED
04-12-2018 03:49 AM
Awesome Jiri!
Thanks for the links I'll work through them when I get back on this project.
05-02-2018 06:05 AM
Sorry that I'm digging this up again, but I have additional questions:
How can I log multiple Tasks? The example only shows one channel group. From that alone I can't really understand what needs to be done to log some data to a second task, e.g. a slower task.
I've tried generating a second capture Task, but it does not show up in the file.
Is there any more Documentation on the Trigger Conditions for IConditionWatcher? I can figure out what posedege(enginePower, 0.5) does, but what else can it do?
Finally, how come they can pass a Task Name formatted differently to "TaskN" in this document by dSpace? In Chapter 5.5 the example seems to show this, yet with VeriStand I get an exception.
