The NI-Switch Relay add-on allows users to use NI Switch relay devices inside NI VeriStand. These are commonly used to switch power and ground, but could be used to switch anything through a relay.
To use the NI-Switch relay add-on:
Follow the instructions in the included ReadMe.txt file
The nature of some add-ons requires additional software or hardware to function.
This device was created for use with NI VeriStand. To use this custom device you must have the following software installed:
Any NI-Switch product with relays.
This add-on is provided as open-source software. If it does not meet your exact specification, you are encouraged to modify the source code to meet your needs. It is not officially supported by National Instruments.
If you encounter a problem with this add-on, or if you have suggestions for a future revision, please post to the forum for this add-on NI-Switch Relay Add-On Feedback. You must use this feedback forum for support. Do not call National Instruments for support for this add-on.
National Instruments does not support this code or guarantee its quality in any way. THIS EXAMPLE PROGRAM IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND AND SUBJECT TO CERTAIN RESTRICTIONS AS MORE SPECIFICALLY SET FORTH IN NI.COM'S TERMS OF USE (http://ni.com/legal/termsofuse/unitedstates/us/).
Doesn't work. It gives the error that NI-Switch Inicialization doesn't exist
Sometimes when VeriStand is unable to find Initialization.vi, it's because you've added the same custom device into the C:\Users\Public Documents\VeriStand 20xx\Custom Devices folder twice. Can you search through that folder (and all subfolders) and verify that you don't have Switch/Relay added twice?
Also, this page is generally not moderated for support questions. If you have further questions, I'd encourage you to post them to the discussion linked at the bottom of this post under "Support and Contact." Thanks!
