04-18-2018 09:27 PM
Are you sure you loaded this into a new project? Those errors look like reload issues.
If you load this into a new project, you should get errors complaining about line 13, which if you open the file you'll notice there's an empty category. Delete lines 12 through 14 and it should load.
To fix the empty category, go back into the node and check your config there. But, you'll likely have to re-generate and re-compile. You can also manually fix the naming and assignment of channels to categories within the file, just don't change the order of channels since that's how the node has scripted the FPGA code to send them up.
Hope that helps --Ryan_S
04-19-2018 09:00 AM
I started over again with a new project and tracked my steps. See attached; same result. I deleted lines 12 through 14 but it didn't reload.
04-19-2018 09:16 AM - edited 04-19-2018 09:20 AM
Okay, so I was able to check with my "go to guy" here onsite. I needed to go get NI VeriStand FPGA DMA.xsl and NI VeriStand FPGA DMA.xsd out of C:\Users\Public\Documents\National Instruments\NI VeriStand 2016 and place them in the same folder as my .fpgaconfig and .lvbitx files. I did have to delete the empty category also. That is the solution to error 2628.
05-23-2018 04:34 AM - edited 05-23-2018 04:43 AM
Hi Ryan,
I've installed all the packages as per the document suggests but when I put down the XML Builder node onto the Block Diagram, LabVIEW searches for three missing DLLs.
NationalInstruments.VeriStand.SystemStorageUI.dll
NationalInstruments.VeriStand.SystemStorage.dll
National Instruments.VeriStand.SystemDefinitionAPI.dll
Where can I find these/what am I missing from my installation?
HPT
EDIT: All solved. Didn't follow the installation instructions to the T and missed out the LabVIEW Config File step.... (doh!)
05-24-2018 01:52 PM
I am working on an I/O package that is mostly Boolean values. I hit the 500 Node limit, is there a way to increase this value?
-Lee
07-09-2018 08:00 AM
Working with the Veristand XML Builder (Great job by the way), I could successfully generate the fpgaconfig and use it into Veristand.
But for some time, when I need to re-generate the XML file, I got first "Success", with the dimensions to be given to the DMA FIFO, but just after I keep getting Error 8
Date: 09/07/2018 Time: 14:53 Error: 8 Error Source: Open/Create/Replace File in Xnode Build XML.vi->XNode_BuildAction.vi->FPGA XML.xnode:GenerateCode.vi->FPGA XML.xnode:GenerateCode.vi.ProxyCaller<APPEND> C:\Users\Public\Documents\National Instruments\NI VeriStand 2017\FPGA\cRIO-9039 Veristand FPGA.fpgaconfig
This error seems to appear randomly. The FPGA config file is not generated.
EDIT : A workaround was to change the base folder in the XML Builder from C:\Users\Public\Documents\National Instruments\NI VeriStand 2017\FPGA to a place without any space (Desktop for instance)
07-09-2018 06:27 PM
Yikes, that's a lot of booleans...
The 500 max is hard coded within the node (regrettably) but if you can find the initialization VI for the node you might be able to change it locally. I don't remember where that is though. But I don't know if that's the right approach here...
Normally with that many bools you'd want to bring them in as ports, and read/write to VS as U8's. That does mean your models either need to accept them as ports or you need a simple LabVIEW model to convert the port into indivual booleans. You lose one tick of the PCL for that, but it's almost always a better solution than bringing that many individual booleans up/down...
07-09-2018 06:32 PM
This error is coming from the LV primitive, nothing special from the node. Likely causes are either:
1. You have a system definition open that is referencing the XML while you're try to generate
2. You have the XML file open in an editor like notepad++
3. Somehow your public documents folder has had permissions added to it (unlikely)
I'm guessing it's 1 or 2, and moving to a new location simply meant the app that was referencing the active copy (either VS or a text editor) no longer got in the way.
07-10-2018 09:03 AM - edited 07-10-2018 09:03 AM
It's not totally wrong...
Closing the Veristand System Definition (and even the application) as well as any Notepad-like app which might be using the XML file, the file is properly generated... But I still got the error.
So, being sure that nothing is using the file at generation time, I might encouter the error, but the file is generated. That error does not come systematically.
It's not very big issue, but it is needed to know that the file is correctly generated even with the error prompting.
07-10-2018 11:52 AM
We found a way to reduce the I/O count.
