NI VeriStand Add-Ons Discussions
Scan Engine & EtherCAT Custom Device Feedback
Welcome to the Scan Engine & EtherCAT custom device feedback forum. Please  provide questions or comments with regards to this custom device in  this forum.
Message 1 of 676
(127,183 Views)
I'm trying too deploy the Scan Engine @ EtherCAT Custom Device on a cRIO-9024 with a 4 slot chassi in Veristand 2010. If a configure the custom device with no modules their is no problem to deploy to the cRIO. If I add any modul or modules to the chassi and also add them in the custom device I get the errorcode: 537702 According to the documentation of the Scan Engine custum device: "There was a mismatch between the modules configured in the system definition and what was detected on the target system." I have attached the complete deployment log below. What is wrong?
Henrik Ulfhielm
____________________________
• Loading System Definition file: C:\Dropbox\Novator\Veristand\DEMO Volvo CE\DEMO Volvo CE.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target AEcRIO9024.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting download for target AEcRIO9024...
• Opening FTP session to IP 192.168.1.43...
• Processing Action on Deploy VIs...
• Gathering target dependency files...
• Downloading DEMO Volvo CE.nivssdf [109 kB] (file 1 of 7)
• Downloading DEMO Volvo CE_AEcRIO9024.nivsdat [262 kB] (file 2 of 7)
• Downloading Scan Engine RT Driver.vi [111 kB] (file 3 of 7)
• Downloading Scan Engine Timing Source.vi [19 kB] (file 4 of 7)
• Downloading Scan Engine - RT.llb [10543 kB] (file 5 of 7)
• Downloading Modules.lvlibp [2634 kB] (file 6 of 7)
• Downloading FXP.llb [7302 kB] (file 7 of 7)
• Closing FTP session...
• Files successfully deployed to the targets.
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 537702 occurred at Project Window.lvlib:Project Window.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (537702) or for its hexadecimal representation (0x00083466).
• Unloading System Definition file...
• Connection with target AEcRIO9024 has been lost.
Message 2 of 676
(18,600 Views)
Hi Henrik,
One possibility is that there is an FPGA configuration deployed to your target and the slots you are using are not available for scan IO.  However, even without a custom FPGA bitfile deployed, on occaision I have seen the underlying API used by the Scan Engine CD fail to detect modules in a cRIO chassis.  This sounds like the behavior that you're seeing.  Unfortunately I haven't seen this often enough to know why it is occurring, but in the past I have gotten around this by deploying a chassis configuration to the target from a LabVIEW project.  If you do not have LV and LVRT installed, another possibility you might try is uninstalling and reinstalling the NI Scan Engine and EtherCAT components to your cRIO from MAX.  Hopefully this should "reset" your cRIO and allow you to detect the modules properly.
Unfortunately there is not an API currently available to switch a cRIO between Scan Mode and FPGA mode, so I can't offer that functionality through the custom device (the only way to switch currently is from a LabVIEW project).  However, I'm expecting to see this functionality added shortly, at which time I will add it to the custom device.
Devin
Message 3 of 676
(18,599 Views)
Hi Henrik,
if you install NI-RIO 4.0 (August 2011), it is switched to Scan mode by default.
Jiri
CLA, CTA
Message 4 of 676
(18,600 Views)
I am starting a project in LabVIEW 2011/VeriStand 2011. What do I need to do to get this to work in 2011 versions?
Thanks!
Message 5 of 676
(18,600 Views)
I am trying to use a cRIO-9024 and cRIO0-9118 with VeriStand 2011 and the 2011 Scan Engine & EtherCAT Custom Device.  I have added the custom device in the project explorer and added a local chasis.  I then selected the modules that match my configuation, saved, and deployed.  I get the same error (537702) when I try to deploy the setup.
I have tried reformatting the cRIO and re-installing the software, including the files for the addons.  I have also tried using a LV project to verfiy that the system is in Scan Mode rather that the FPGA interface and have cleared the FPGA memory.
What else could be keeping the add-on from deploying properly?
Thanks in advance for any advice,
Aaron
Message 6 of 676
(18,600 Views)
