06-10-2013 09:18 AM
Hey Michi,
In the version of the steps built for VeriStand 2012 (2.0 and later) there are no longer module tabs on any of the steps. What used to be contained in the module tab is contained in a post step for the step type. These can be seen if you go to the type menu (CTL+T) under NI_Veristand_types.ini. The configure dialog for the step stores the parameters used for the step in the property browser.
Let me know if this answers your questions.
Kevin
06-12-2013 10:06 AM
hey Kevin,
I think that´s it. Thanks!
But now I´ve got an other problem... when I analyze the sequenze there are some warnings in the analysis results. They all leads me to the same spot but I just can´t figure out what the meanig of these settings is!?
Thanks!
Michi
06-12-2013 10:42 AM
Hey Michi,
I fixed those analysis errors in the latest version of the steps (2.2). The fix is essentially to add a #NoValidation directive around the Local variables used by the steps. Since these variables aren't created until run time they fail validation. To install the new version of the steps just uninstall the current version and install the latest installer. Since all the customization of the steps is contained in substeps your sequences should update.
06-13-2013 03:30 AM
Hey Kevin,
it seems to work on severel warnings of the analyze results but some of the same kind are still there. Could there be another reason for this error?
Michi
06-13-2013 03:35 AM
Oh, I just saw that I posted you one of the other warnings...
06-13-2013 08:22 AM
Hey Michi,
A lot of the steps have the local variables in them so you will have to replace them in every location (or just install the 2.2 version of the steps).
Kevin
06-13-2013 09:08 AM
When I installed 2.2, I saw this same problem.
I went to add/remove programs and saw two entries for NI VeriStand 2012 Custom TestStand Steps. So I uninstalled them both and reinstalled 2.2. That worked
06-14-2013 04:12 AM
Hey Kevin, Stephen,
I had installed the 2.2 version but at first these warnings were still there. Now it works! Thanks a lot!
Michi
06-19-2013 01:20 PM
Kevin,
I noticed after I installed version 2.2 that I have two VeriStand folders added to my "Step Types" pane in TestStand ("VeriStand" and "NI VeriStand"). This might be an artifact from the previous version. Just pointing this out for future fixes. I uninstalled the previous version prior to install version 2.2.
06-19-2013 01:26 PM
Hmmm,
Everything should be grouped under the NI VeriStand folder since I removed the VeriStand folder in the 2.2 release. I will look more into it.
