08-11-2017 05:47 AM
I find a strange situation, sometimes TESTSTAND 2013 runs step wait more time, suddenly pops test error report shown system level exception, then report error code -17500 when terminates TESTSTAND 2013. I don’t know why and how to solve.
Solved! Go to Solution.
08-14-2017 09:52 PM
I have no idea about your issues and got that the error code means "The execution failed because the RTS reported an error. The RTS error displays as part of the error message." Here RTS is short for Run Time system.
Some proposes for you:
1, try to run the sequence and trace where it complain the strange error after analyzing it;
2, post more details if possible might some masters on the forum will help you.
08-15-2017 08:36 AM
Thank you very much.
I have found where the problem is. step telnet connection should not record this result of each iteration in the Looping of properties. Because long time running to search telnet connection causes the records very huge and causes teststand error. So cancel records, teststand runs well again.
