02-02-2016 07:53 AM
Something has changed in my Teststand set up as I used to see each step in my sequence file as it was being executed in single pass mode
but now it does not display each step.
Is this a setting or some configuration that I need to change in order to see each step as it is being executed in my Seq file?
thanks
02-02-2016 08:11 AM
robojeff,
Try Configure > Station Options > Execution tab, and make sure tracing is enabled.
02-02-2016 08:27 AM
awesome thanks Daniel!
