04-03-2018 09:41 AM
I'm trying to us the NI_MultipleNumericLimitTest with "Repeat Measurement Set" "ON" to perform the following:
1. locals.Array as the data source "[0..10]" array size
2. For the low limits "Parameters.low[x]"
3. For the Upper limits "Parameters.high[x]"
I'm just not sure how to index the array to point to the following
Locals.array[0] should use limit Parameters.low[0], Parameters.high[0],
Locals.array[1] should use limit Parameters.low[1], Parameters.high[1]
Locals.array[10] should use limit Parameters.low[10], Parameters.high[10]
any thoughts?
04-05-2018 09:10 AM
Hi Ccyclone128a,
Just to clarify, both your data source, as well as the parameters, are size 11 arrays? And you want to index through three of these arrays?
