I have a CVI project that has several FP files and three C files, along
with a few header files. One of the C files is tscvirun_supp.c and I
have it configured to be built as an object file prior to running.
My problem is this:
If I have TestStand configured to use the CVI adapter and use an external
instance of CVI, my sequence runs fine. I can point to either C files
or OBJ files and everything runs.
If I try to configure the CVI adapter to run In-Process I get an error
from TestStand that it can't get a CVI step module address on the first
function I call. It can't find the function being pointed to by the
sequence step.
I have configured AutoLoadLibs with the default CVI libraries along with
any files required by my sequence
. I also put my OBJ files in AutoLoadLibs
and my DLLs are in the system path.
What does CVI do for me that I am missing when CVI isn't running?
I've tried everything I can think of and converting to DLLs instead of
object files isn't a good option. Is there something specific I need to
do when I create my object file(s)?
-Steve
________________________________________________________________________
Steve Heitke Tellabs Operations, Inc.
heitke@tellabs.com Advanced Test Methods
http://www.tellabs.com Bolingbrook, IL 60440
