NI TestStand
uir file not found (error 94) while executing CVI dll in TestStand
I am trying to run a dll I created in CVI in TestStand.  I haven't had any problems so far running any of the functions except for the function that calls my user interface.  Every time I run it I get an "Error 94, file "....uir" not found".  This particular uir is usually called in the main() function when I create an exe file in CVI, but I'm calling it from another function to execute in TestStand.  Any suggestions on how to fix this?
(3,323 Views)
Accepted by topic author Clayton Bigsby
Are you using the correct LoadPanel call. You should be using LoadPanelEx().
Regards
Ray Farmer
Regards
Ray Farmer
(3,313 Views)
This is what I ended up trying yesterday.  Everything works now!  Thanks for your help
(3,296 Views)
