NI TestStand
ts.starttime
for each step there is a parameter named TS.StartTime. The TestStand ReferenceManual explains it as "the number of seconds since the TestStand Engine initialized". I do not realy understand when the TestStand Engine initializes. What I need is just the start time of each step (i.e. sequence call) in my main sequence to have a start and end time for each of it. I can evaluate the end time of a step with TS.TotalTime, but to do this I need a start time.
Thanks a lot and regards
Nicole
(2,316 Views)
Hi Nicole
Maybe this forums entry will help you.
regards
Manuel
(2,292 Views)
Nicole -
The value in the TS.StartTime is similar to the Seconds expression function.  You can use the Date and Time expression functions to convert the output of Seconds to a formated string or individual values.  The key is to pass the seconds value to parameter 6 and True for parameter 7 of the Date or Time functions.
If you want to know when the engine started, you can determine this by calling the expression: 'Seconds(False) - Seconds(True)', or using the API by calling 'Engine.SecondsSince1970UniversalCoordinatedTime() - Engine.SecondsSinceStart()'.
Scott Richardson
(2,278 Views)
