08-30-2020 04:00 AM
Hi Sir,
My teststand will generate the xml test report, can see the total test time.
But i want to breakdown the test time, and see it for each step.
How to config it, then the test report will record the test time for each step ?
08-31-2020 02:02 AM
You can add the time value to the report by using the following:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8tKSAS&l=hu-HU
You can also add to be visible in the SequenceEditor:
https://forums.ni.com/t5/NI-TestStand/Displaying-the-module-time-for-each-step/td-p/3759197
08-31-2020 02:51 AM
hello,
I go through that, but still have not seen how to make it happen.
Thanks.
08-31-2020 04:09 AM
The answer is in this forum link:
Basically, the XML default stylesheet (horizontal.xsl) doesn't display it so, you will need to update it to any of the other two options.
