NI TestStand
teststand no response
teststand no response after excution and before report created.please have a look , thanks.
(4,279 Views)
Are the models you use the default TestStand models?
Does it also occur with NI example sequences?
Norbert
Norbert
Expert: Geometry
(4,261 Views)
Hi Norbert,
thank you for reply, yes, it is also happed on NI example sequences even I disable report generation.  and I use the default teststand models.
(4,221 Views)
What does "no repsonse" mean?
Is it a complete hang? What do you do in order to resume execution?
Norbert
Norbert
Expert: Geometry
(4,120 Views)
yes, it is complete hang, shutdown teststand and re-execute.  I guess there are something confict with report setting and option.
(4,110 Views)
I assume that you somehow placed a break point in the process model or the report generator.
Another option is that you open a dialog which is not displayed (second monitor?) which is blocking execution.
Norbert
Norbert
Expert: Geometry
(4,107 Views)
What do you mean by complete hang? Do the menu items function? How are you shutting down teststand if it's hung?
-Doug
(4,097 Views)
