01-12-2014 08:27 PM
teststand no response after excution and before report created.please have a look , thanks.
01-13-2014 03:59 AM
Are the models you use the default TestStand models?
Does it also occur with NI example sequences?
Norbert
01-13-2014 07:11 PM
Hi Norbert,
thank you for reply, yes, it is also happed on NI example sequences even I disable report generation. and I use the default teststand models.
01-16-2014 02:39 AM
What does "no repsonse" mean?
Is it a complete hang? What do you do in order to resume execution?
Norbert
01-16-2014 04:53 AM
yes, it is complete hang, shutdown teststand and re-execute. I guess there are something confict with report setting and option.
01-16-2014 06:03 AM
I assume that you somehow placed a break point in the process model or the report generator.
Another option is that you open a dialog which is not displayed (second monitor?) which is blocking execution.
Norbert
01-16-2014 09:03 AM
What do you mean by complete hang? Do the menu items function? How are you shutting down teststand if it's hung?
-Doug
