09-18-2008 03:05 PM
I wish to add 3 bar code into the HTML report, I have a barcode font which i wish to use. How can i specify certain string(i.e serial number) to be this font ? I am currently modifying the reportgen_html.seq. I have specified the new font in expression "Add HTML Prefix" but teststand defaults to the standard font.
Need help !
09-18-2008 04:45 PM
I have got something working, I have been having trouble using "Bold" Font though, any other tips would be of help 🙂
09-18-2008 05:05 PM
ds1638,
Can you please clarify what is the issue with the bold font? What are the rows in the header would you like to display in bold?
Regards
Anand Jain
09-18-2008 05:09 PM
09-18-2008 05:12 PM
ds1638
Html display any text you add within <B> and </B> as bold. I would suggest looking at the expression that you are using to add the barcode and remove <B> tags.
Hope it helps
Regards
Anand Jain
09-18-2008 05:39 PM
Hi, thanks for your suggestion. I have just removed the <B> and the bar code is still not readable, I reduced the font size and now it is working correctly.
thanks your your help, now I know what the <B> expression is for.
09-18-2008 05:44 PM
ds1638
I am glad you were able to resolve this issue.
FYI - I use http://www.w3schools.com/ as a good reference for web based technologies - They also have a good html tutorial.
Regards
Anand Jain
