07-13-2012 08:53 AM
I have subsequences in my Main Sequence. In the current file. Is there some attribute or something I can set so that this subsequnce doesn't report pass/fail when I call it in another subseq?? In other words I have a subseq called powerdown.seq. In another sub seq I do some testing then in the clean up I call powerdown seq. This is done many times in diff subseq. Each time powerdown.seq reports pass fail. Do I have to go into each subseq and deselect the "Record Result" button in "Run Options"?? Is there any where I can do it 1x?
07-13-2012 02:25 PM
For your powerdown.seq using the ActiveX module you can set the property for that sequence to DisableResults
Sequence.DisableResults
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
