NI TestStand
simple OI with create new user
Hi Nestor_G,
Please help  I am stuck
Please do a deploy with the Add/Delete User button in simple OI
why deploy different from development?
I don't know why does it jump to NI MAX?????????????????
Message 11 of 13
(1,046 Views)
Hi trout00,
You will also need to deploy ToolMenu.ini found in: C:\Documents and Settings\All Users\Application Data\National Instruments\TestStand 4.1\Cfg . NI MAX is executing because this application is by default the first item in the Tools Menu. Deploying the ini file will add your new tools menu item.
If you have any custom search directories, you will also need to deploy TestExec.ini found in the same Cfg folder.
Nestor
Message 12 of 13
(1,039 Views)
Thank Nestor_G,
All went well,
I need to copy the correct  tool .ini and report .ini for text report
Again Thank for helping
Message 13 of 13
(1,029 Views)
