NI TestStand
rounding after comma
Highlighted
(245 Views)
Highlighted
(244 Views)
NOTE:  In both examples, Locals.Roundee is the number you want to round.
For your first examples
Round(Locals.Roundee,0)
For your second examples
Val(Str(Locals.Roundee, "%#.1f"))
(190 Views)
Highlighted
Doh! Just seen the "Up if 5" bit on your post.  My examples will "Down if 5".  I think if you want "Up if 5" that will be a pretty complicated statement.
(187 Views)
Highlighted
Accepted by hkn10
If you use 4 for the Round option, then it will use "banker's rounding" which will round 0.5 to the nearest even integer.  So for the second example use
Locals.Roundee = Round(Locals.Roundee*10,4)/10
To multiply and divide by 10 are to shift the decimal point (or comma) to the left before the round (to round to the nearest 0.1) and to the right to undo the shift after the rounding.
GCentral
(170 Views)
