NI TestStand
rounding after comma
(1,250 Views)
(1,249 Views)
NOTE:  In both examples, Locals.Roundee is the number you want to round.
For your first examples
Round(Locals.Roundee,0)
For your second examples
Val(Str(Locals.Roundee, "%#.1f"))
(1,195 Views)
Doh! Just seen the "Up if 5" bit on your post.  My examples will "Down if 5".  I think if you want "Up if 5" that will be a pretty complicated statement.
(1,192 Views)
Accepted by topic author hkn10
If you use 4 for the Round option, then it will use "banker's rounding" which will round 0.5 to the nearest even integer.  So for the second example use
Locals.Roundee = Round(Locals.Roundee*10,4)/10
To multiply and divide by 10 are to shift the decimal point (or comma) to the left before the round (to round to the nearest 0.1) and to the right to undo the shift after the rounding.
GCentral
(1,175 Views)
