There are several ways to get around this, but the simplest for me is to do the following:
1) Configure Report Options to "Specific Directory" and enter a defult Path.
2) Add a Report Options Callback to you sequences and set the "Parameters.ReportOptions.Directory" string to be your new Report Path.
You can easily make this generic code to copy into both sequences by using the sequence file path. "RunState.SequenceFile.Path" will give you the full path of your sequencefile.
The following Expression will set the report path to be in a folder "Report" under the current sequence files path. (eg.for C:\laptop\mylaptop.seq it would put the report in C:\laptop\report)
Parameters.ReportOptions.Directory = Left( RunState.SequenceFile.Path, Find( RunState.Sequence
File.Path, "\\", 0, false, true ) ) + "\\Report"
Hope this helps
Simon Holman
CPE Systems Pty. Ltd.
Ph: (+613) 9419 1499
Fax: (+613) 9419 1411
web: www.cpesys.com.au
email: sholman@cpesys.com.au
Simon Holman
Software Engineer
Certified LabVIEW Developer
Certified TestStand Developer
measX GmbH & Co. KG.
http://www.measx.com
