NI TestStand
report header from a spreadsheet
I am using teststand 4.0 & for report geneartion .xml format. I want to know is that report header can be obtained from a excel spreadsheet.This configuration i want to make it only once not for every sequence i make every time i.e, i want the header information should be taken form excel spreadsheet every time i run a sequence   automatically every time. This should automatically apply to every sequence i make.
(2,725 Views)
Hi praveen,
You can use a Modify Report Header callback. This must help you not to change the report header for  sequences.
(2,716 Views)
Is your problem solved? Do let us know if you have further queries.
GauravI
(2,708 Views)
No. What ever i write in report header is being reflected in the results sheet. Only the things which i do through expand.xsl sheet is getting reflected in the result.
(2,706 Views)
