NI TestStand
report generation inconsistent
When I run my sequence file in interactive mode for multiple executions using Loop on selected steps using>>TestUUTs entry point (say for 500 times) then only the report header gets generated. This is with generating xml reports.
Maybe the ResultList array is getting very huge inthe memory?
If the option to generate Report on the Fly is enabled then the report gets written but the execution really slows down:(
Is there any suggestion as to why full xml reports will not get generated (only the header get written out) when interactive execution is performed and looped for 500 times or greater? I am using TS 4.1.
Thanks!!
CLD
(2,427 Views)
On the station options dialog, make sure you have the option to record results for interactive executions checked.
Hope this helps,
-Doug
(2,403 Views)
