NI TestStand
reload prototype is not working with LabVIEW DLL with clusters
The LabVIEW DLL which I have created are not loading the prototypes in TestStand.
I have selected C/C++ Dll as the Adapter type in TestStand. It is showing following popup
"This function either does not have parameter information in the DLL or uses types not recognized by TestStand".
I found out that this issue is because of the Error Cluster as the parameter in DLL.
Can anyone tell me how can I solve this issue caused by cluster as parameter in the DLL?
Thanks in Advance...
Into the pursuit...
Maverick
(4,300 Views)
Maverick,
I'm having the same problem.  This may help you:
http://digital.ni.com/public.nsf/allkb/22BF02003B4588808625717F003ECD67
What versions of LabVIEW and TestStand are you using?
(2,977 Views)
