07-14-2017 02:30 AM
Hii,
how do we read the Revision number(SVN tortoise) of the Seq file in Teststand .
I Need to log this number in the test protocol
regards
Akshay
07-14-2017 02:51 AM
I do not know the SVN command lines very well, but with TortoiseHg for Mercurial we use a "Call Executable" step with the following command line:
hg identify --num "PathToRepository"
catch the output in a Local string variable using the "Output Destination: Store in Variable/Property" setting on the "Standard Output/Error" tab of the "Call Executable" settings and parse that in the PostExpression by
Locals.StationRevision = Trim(Locals.StationRevision,"\n")
to have the RevisionNumber in a Local variable (which is a string in this case, but could be converted to a number using Val()).
Hope that helps.
Peter
07-17-2017 02:19 AM
Hello aparab,
you can try
"C:\Program Files\TortoiseGit\bin\TortoiseGitProc.exe" /command:log "path to SVN working directory"
Appendix D. Automating TortoiseSVN
07-17-2017 05:17 AM
This question relates to svn only, and I wrote a simple project to back svn repository years ago.
You could try the command svnlook youngest
07-17-2017 07:24 AM
Hii all,
thankyou all for your helpfull suggestions.
I will start in LIFO (lastin first out)
1. svnlook youngest <filepath> unfortunately does not provide the Rev. No. , i have gone through a literature suggesting it works on Server side. But my machine is a Client thts the Logical explannation i could find.
2. TortoiseGitProc.exe my SVN Client does not include this Executalble.
I will post my soln.. later
regards,
Akshay
07-17-2017 07:26 AM
"/c svn info "+RunState.SequenceFile.Path
gives me the result almost, well it dumps all info including Rev. number. but seems fine.
