NI TestStand
"member not found" error
when running TestStand 1.0.1 I get an error when trying to log to the database in the test UUT model.
I get the followong message "member not found" in the "open uut result SQL statement" step under the"Log UUT Results" sequence.
(3,114 Views)
Hi Emil,
This could be due to the version of MDAC you have installed on your machine.Generally, MDAC 2.5 and higher are incompatible with the LabWindows/CVI SQL Toolkit functions TestStand 1.0.x uses to interact with databases. Therefore, it is best to use either MDAC 2.0 or 2.1 with TestStand versions 1.0.x (since this is the version of MDAC that TS 1.0.x ships with).
Note: Reinstalling TestStand is not going to cause it to reinstall the proper version of MDAC if you have a newer version of MDAC already on the machine. You must visit the Microsoft link (see below) for information on how to remove the newer version before installing an earlier version in its place.
Information on discovering your current MDAC version, how to obtain version 2.1, and how to rol
lback versions is available at the following Microsoft website:
http://www.microsoft.com/data
(3,114 Views)
