NI TestStand
preuut and postuut sequences are not executing when run using UI. They run when using the sequence editor.
I am using TestStand 3.5 and LabVIEW 8 in a Windows XP environment.
I have a sequence that runs properly when run from the sequence editor.  I have made a few minor mods to the simple Operator Interface that ships with TestStand.  When I run my sequence using the modified Operator Interface, the PreUUT and PostUUT sequences do not execute.  Only the main sequence executes.  This also happens when I run the demo sequences that ship with TestStand.
What am I missing?
(2,738 Views)
It sound like you are executing the sequences without the process model, do you get a report at the end of the execution?
What are these minor mods you have done?
Regards
Ray Farmer
Regards
Ray Farmer
(2,729 Views)
Yes, the process model is not being run.
The problem is caused by leaving the index unwired when using the ConnectCommand Method.  With the index unwired only the main sequence executes and the process model is not used.
Thanks for the help.
Steve
(2,723 Views)
