NI TestStand
passing data from one labview exe to another
I did it in a different way, I converted both the VIs into .dll and called both of them in another vi and finally made an exe of the final one.
Its working pretty fine now.
Regards
Sreedhar.
Message 11 of 15
(2,514 Views)
To just add a quick comment, you do not have to create exe's or dll's from LabVIEW VI's in order to run them on a system without the LabVIEW development system. Read chapter 5 of Using LabVIEW with TestStand and chapter 14 of the TestStand Reference Manual.
Message 12 of 15
(2,503 Views)
I am unable to communicate between both the ExEs. Will be helpful if you attach the exe of your working VIs. I made the exes under default settings. Sorry I am unable to attach as my system is not helping me to do so.
Thanks.
Message 13 of 15
(2,504 Views)
Did you enable the ActiveX Server for each application? Also, as Ray mentioned, your paths are much different with exe's. Getting both of these correct are why I recomended that you avoid using exe's.
Message 14 of 15
(2,491 Views)
As I said, I tried using default settings for making the exe. Now, after I enabled the activeX server, there is no difference.
Message 15 of 15
(2,486 Views)
