NI TestStand
pass cluster through DLL to Teststand
I have to pass  Time Stamp & number thr'  a cluster in a DLL to Teststand
thts  generating error  System Level Exception.[Error Code: -17502]
the Cluster ProdOrder(in pic ) is generating Issues
Message 1 of 15
(6,825 Views)
the Custom datatype tht I have to generate for this Cluster in teststand  cld be also   the culprit
I have added the Mytypes ini file  where I have defined     the datatype as ProdorderMYINI
Message 2 of 15
(6,818 Views)
the dll file
Message 3 of 15
(6,817 Views)
Hi Aparab,
Thank you for your message.
Could you please have a look at this document:
Passing Structured Data Types Between TestStand and a LabVIEW DLL
http://digital.ni.com/public.nsf/allkb/22BF02003B4588808625717F003ECD67
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
Message 4 of 15
(6,792 Views)
Thanks Julien,
have already taken care of the doc.
Message 5 of 15
(6,790 Views)
Hi Aparab,
have you already seen this Knowledge Base:
http://digital.ni.com/public.nsf/allkb/901B5E1C33A102A18625671C007C501F?OpenDocument
Julien De Freitas
Message 6 of 15
(6,774 Views)
thanks
but i am using a DLL adapter  & not activex
Message 7 of 15
(6,769 Views)
Could you please configure the DLL adapter?
Thank you
Julien De Freitas
Message 8 of 15
(6,766 Views)
as u see in the png the dll adapter has only 1 imp setting the struct packing which  I have set already
regards
akshay
Message 9 of 15
(6,763 Views)
could you please check the settings for your custom data type in TestStand. I am sending you a screenshot.
Julien De Freitas
Message 10 of 15
(6,756 Views)
