07-16-2014 08:40 AM
I have to pass Time Stamp & number thr' a cluster in a DLL to Teststand
thts generating error System Level Exception.[Error Code: -17502]
the Cluster ProdOrder(in pic ) is generating Issues
07-16-2014 10:02 AM
the Custom datatype tht I have to generate for this Cluster in teststand cld be also the culprit
I have added the Mytypes ini file where I have defined the datatype as ProdorderMYINI
07-16-2014 10:03 AM
the dll file
07-17-2014 07:32 AM
Hi Aparab,
Thank you for your message.
Could you please have a look at this document:
Passing Structured Data Types Between TestStand and a LabVIEW DLL
http://digital.ni.com/public.nsf/allkb/22BF02003B4588808625717F003ECD67
07-17-2014 07:34 AM
Thanks Julien,
have already taken care of the doc.
07-18-2014 01:16 AM
Hi Aparab,
have you already seen this Knowledge Base:
http://digital.ni.com/public.nsf/allkb/901B5E1C33A102A18625671C007C501F?OpenDocument
07-18-2014 02:11 AM
thanks
but i am using a DLL adapter & not activex
07-18-2014 02:17 AM
Could you please configure the DLL adapter?
Thank you
07-18-2014 02:40 AM
as u see in the png the dll adapter has only 1 imp setting the struct packing which I have set already
regards
akshay
07-18-2014 04:27 AM
could you please check the settings for your custom data type in TestStand. I am sending you a screenshot.
