NI TestStand
parallel model and locking
Is there an option to ensure that some code within a labwindows code module is executed atomically  ?  That means that Teststand doesn't switch to another (parallel running) thread within that code sequence.
(2,969 Views)
You can do synchronized sections in TestStand.  Use the Batch Synchronization step and set the Section Type to One Thread Only, Serial or Parallel.  Then use the same step type to Exit the synchronized section.
Also the Auto Scheduler is pretty cool for locking resources.  Check it out in the examples.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,963 Views)
