NI TestStand
opening a teststand generated xml
I have a test stand application that generates the test data record in the form of an xml file.  I started having problems trying to open those files if I try to forward them to anyone.  It seems to be the case with all of my test stand generated data recrods.  Some computers will open the attachements just fine while other will not open the same files.  Does my operating system matter?  I have attached two png files and a horizontal xls file just like I have always done.  I can they get corrupted over the course of time?  These data folders have been in place for years.  Any thoughts would be appreciated, thank you.
Mario Cuesta
480-441-8320
(4,170 Views)
Hi Mario,
The issue may be that the stylesheets that the XML reports use are located in different places on the target machine, for example due to path changes based on the operating system.  Even if you include the stylesheet, the reports will still look for it in a specific TestStand location.  You can use the XML packaging utility to package the XML file and all required stylesheets and images into a single directory.  The tool will fix all paths to the dependent files as well, so the report will always load correctly. The utility is here:
<TestStand>\Bin\XMLPack.exe
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(4,155 Views)
thanks for the reply.  I cannot see or retrieve the attachement though.  Is that something I can search and download from the NI website?
(4,100 Views)
The utility is installed with TestStand.  It is located here:
C:\Program Files\National Instruments\TestStand 2014\Bin\XMLPack.exe
Al B.
CTA/CLD
(4,094 Views)
