08-21-2012 10:19 PM
With On The Fly reporting enabled, custom report under TestReport Callback does not gets created. Even removed the precondition to skip the TestReport Callback. How to get the custom report created? Not sure how is Write UUT Report which calls Save method of TSOnTheFlyReportGen different from Report Object Save method?
Solved! Go to Solution.
08-23-2012 10:48 AM
I'm not sure I completely understand what part of the report customization isn't being created, but take a look at the this KnowledgeBase article. It talks about how to how to get ModifyReportHeader and ModifyReportFooter Callbacks called when using on the fly reporting.
Hope this helps.
