From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
missing "api-ms-win" dll in Teststand sequence
I am trying to reuse a legacy TestStand 4,0 code which is running in a WinXP computer. I am planning to use it in a Win10 pc with TestStand 17.0.  I am getting these below missing dll in my laptop with Win10 but it is working fine on another laptop with Win10.
Both Laptops are having same drivers, Teststand and cvi installed.
I believe these are windows based dll. I tried to install Windows SDK but it is showing that the SDK in my laptop is already a latest one.
I also tried SFC, (DISM.exe /Online /Cleanup-image /Scanhealth) and (DISM.exe /Online /Cleanup-image /Restorehealth) on the command prompt, but nothing helped.
Any support will be much appreciated.
api-ms-win-core-console-l1-1-0.dll (Not Found)
api-ms-win-core-console-l1-2-0.dll (Not Found)
api-ms-win-core-datetime-l1-1-0.dll (Not Found)
api-ms-win-core-debug-l1-1-0.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l1-1-0.dll (Not Found)
api-ms-win-core-file-l1-1-0.dll (Not Found)
api-ms-win-core-handle-l1-1-0.dll (Not Found)
api-ms-win-core-heap-l1-1-0.dll (Not Found)
api-ms-win-core-localization-l1-2-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-0.dll (Not Found)
api-ms-win-core-memory-l1-1-0.dll (Not Found)
api-ms-win-core-namedpipe-l1-1-0.dll (Not Found)
api-ms-win-core-processenvironment-l1-1-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-0.dll (Not Found)
api-ms-win-core-profile-l1-1-0.dll (Not Found)
api-ms-win-core-string-l1-1-0.dll (Not Found)
api-ms-win-core-synch-l1-1-0.dll (Not Found)
api-ms-win-core-synch-l1-2-0.dll (Not Found)
api-ms-win-core-sysinfo-l1-1-0.dll (Not Found)
api-ms-win-core-util-l1-1-0.dll (Not Found)
api-ms-win-eventing-provider-l1-1-0.dll (Not Found)
api-ms-win-eventing-controller-l1-1-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-1.dll (Not Found)
api-ms-win-core-crt-l1-1-0.dll (Not Found)
api-ms-win-core-crt-l2-1-0.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-2.dll (Not Found)
api-ms-win-core-interlocked-l1-1-0.dll (Not Found)
api-ms-win-core-io-l1-1-0.dll (Not Found)
api-ms-win-core-registry-l1-1-0.dll (Not Found)
api-ms-win-core-string-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-heap-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-timezone-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-l1-2-0.dll (Not Found)
api-ms-win-core-threadpool-legacy-l1-1-0.dll (Not Found)
api-ms-win-security-base-l1-1-0.dll (Not Found)
api-ms-win-core-apiquery-l1-1-0.dll (Not Found)
api-ms-win-core-delayload-l1-1-0.dll (Not Found)
api-ms-win-core-heap-l2-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-1.dll (Not Found)
api-ms-win-core-rtlsupport-l1-2-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-1.dll (Not Found)
api-ms-win-core-delayload-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-0.dll (Not Found)
api-ms-win-service-core-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-2.dll (Not Found)
api-ms-win-service-management-l1-1-0.dll (Not Found)
api-ms-win-service-management-l2-1-0.dll (Not Found)
api-ms-win-service-private-l1-1-4.dll (Not Found)
api-ms-win-service-private-l1-1-2.dll (Not Found)
api-ms-win-service-private-l1-1-3.dll (Not Found)
api-ms-win-service-private-l1-1-0.dll (Not Found)
api-ms-win-service-winsvc-l1-1-0.dll (Not Found)
api-ms-win-security-base-private-l1-1-0.dll (Not Found)
api-ms-win-core-registry-l1-1-1.dll (Not Found)
api-ms-win-core-registry-l1-1-2.dll (Not Found)
api-ms-win-core-rtlsupport-l1-1-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-3.dll (Not Found)
api-ms-win-core-processthreads-l1-1-2.dll (Not Found)
api-ms-win-core-memory-l1-1-1.dll (Not Found)
api-ms-win-core-memory-l1-1-2.dll (Not Found)
api-ms-win-core-synch-l1-2-1.dll (Not Found)
api-ms-win-core-file-l1-2-0.dll (Not Found)
api-ms-win-core-file-l1-2-2.dll (Not Found)
api-ms-win-core-file-l1-2-1.dll (Not Found)
api-ms-win-core-io-l1-1-1.dll (Not Found)
api-ms-win-core-job-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-private-l1-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-2.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-1.dll (Not Found)
api-ms-win-core-libraryloader-l2-1-0.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-2.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-2.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-0.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-3.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-1.dll (Not Found)
api-ms-win-core-localization-private-l1-1-0.dll (Not Found)
api-ms-win-core-processsnapshot-l1-1-0.dll (Not Found)
api-ms-win-core-processenvironment-l1-2-0.dll (Not Found)
api-ms-win-core-debug-l1-1-1.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-3.dll (Not Found)
api-ms-win-security-base-l1-2-0.dll (Not Found)
api-ms-win-core-comm-l1-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-3.dll (Not Found)
api-ms-win-core-realtime-l1-1-0.dll (Not Found)
api-ms-win-core-systemtopology-l1-1-1.dll (Not Found)
api-ms-win-core-systemtopology-l1-1-0.dll (Not Found)
api-ms-win-core-processtopology-l1-1-0.dll (Not Found)
api-ms-win-core-namespace-l1-1-0.dll (Not Found)
api-ms-win-core-file-l2-1-2.dll (Not Found)
api-ms-win-core-file-l2-1-0.dll (Not Found)
api-ms-win-core-file-l2-1-3.dll (Not Found)
api-ms-win-core-file-l2-1-1.dll (Not Found)
api-ms-win-core-xstate-l2-1-0.dll (Not Found)
api-ms-win-core-xstate-l2-1-1.dll (Not Found)
api-ms-win-core-localization-l2-1-0.dll (Not Found)
api-ms-win-core-normalization-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-1.dll (Not Found)
api-ms-win-core-sidebyside-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-0.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-3.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-2.dll (Not Found)
api-ms-win-core-console-l1-2-1.dll (Not Found)
api-ms-win-core-console-l2-1-0.dll (Not Found)
api-ms-win-core-console-l2-2-0.dll (Not Found)
api-ms-win-core-console-l3-2-0.dll (Not Found)
api-ms-win-core-psapi-l1-1-0.dll (Not Found)
api-ms-win-core-psapi-ansi-l1-1-0.dll (Not Found)
api-ms-win-security-appcontainer-l1-1-0.dll (Not Found)
api-ms-win-security-audit-l1-1-1.dll (Not Found)
api-ms-win-security-audit-l1-1-0.dll (Not Found)
api-ms-win-core-pcw-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-0.dll (Not Found)
api-ms-win-core-memory-l1-1-3.dll (Not Found)
api-ms-win-core-privateprofile-l1-1-0.dll (Not Found)
api-ms-win-core-atoms-l1-1-0.dll (Not Found)
api-ms-win-core-localization-obsolete-l1-2-0.dll (Not Found)
api-ms-win-core-stringansi-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-1.dll (Not Found)
api-ms-win-core-appinit-l1-1-0.dll (Not Found)
api-ms-win-gdi-internal-uap-l1-1-0.dll (Not Found)
api-ms-win-core-apiquery-l2-1-0.dll (Not Found)
api-ms-win-core-winrt-error-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-error-l1-1-1.dll (Not Found)
api-ms-win-shcore-taskpool-l1-1-0.dll (Not Found)
api-ms-win-security-activedirectoryclient-l1-1-0.dll (Not Found)
api-ms-win-mm-time-l1-1-0.dll (Not Found)
api-ms-win-core-path-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-2.dll (Not Found)
api-ms-win-core-psapi-obsolete-l1-1-0.dll (Not Found)
api-ms-win-crt-string-l1-1-0.dll (Not Found)
api-ms-win-crt-runtime-l1-1-0.dll (Not Found)
api-ms-win-crt-private-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-marshal-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l1-1-1.dll (Not Found)
api-ms-win-core-quirks-l1-1-0.dll (Not Found)
api-ms-win-core-psm-key-l1-1-0.dll (Not Found)
api-ms-win-crt-locale-l1-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-1.dll (Not Found)
api-ms-win-core-localization-l1-2-2.dll (Not Found)
api-ms-win-core-version-l1-1-0.dll (Not Found)
api-ms-win-eventing-classicprovider-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-2.dll (Not Found)
api-ms-win-core-url-l1-1-0.dll (Not Found)
api-ms-win-core-registryuserspecific-l1-1-0.dll (Not Found)
api-ms-win-shell-shellcom-l1-1-0.dll (Not Found)
api-ms-win-stateseparation-helpers-l1-1-0.dll (Not Found)
api-ms-win-core-job-l2-1-0.dll (Not Found)
api-ms-win-crt-time-l1-1-0.dll (Not Found)
api-ms-win-core-versionansi-l1-1-0.dll (Not Found)
Message 1 of 11
(3,370 Views)
Did you check if you have the correct VC runtime for the DLL installed?
Anand Jain
NI
Latest supported Visual C++ Redistributable downloads | Microsoft Learn
Message 2 of 11
(3,304 Views)
hi,
Your problem was solved?
I met the similar issue here, i try to update from winXP to win10, lot's of dll not found just like what you see, i had to launch to win7 instead of win10.
Message 3 of 11
(3,182 Views)
Hi Anand_Jain,
Thanks for your reply.
I checked the Visual C++ is installed properly, I also reinstalled it.
still I having same issue.
Message 4 of 11
(3,170 Views)
Hi MADMAD27,
No the issue is still not resolved.
I have a doubt,
Is the problem got solved for you after switching to Win7?
Message 5 of 11
(3,166 Views)
Accepted by PerinkumarG
Hi PerinkumarG,
win7 don't have this issue.
Message 6 of 11
(3,150 Views)
Thanks MADMA27,
I tried on Windows 7 pc and it is not showing those missing dll errors.
this is a temporary solution since I need to run it on a Windows 10 pc, but still this is a progress.
Thanks again.
Message 7 of 11
(3,057 Views)
Any further updates on this? I am having the same issues and unfortunately going back to Windows 7 is not an option for me.
Message 8 of 11
(2,525 Views)
Is it possible to provide a sample DLL and associated code that shows the issue?
Anand Jain
NI
Message 9 of 11
(2,511 Views)
My missing DLLs were the same as OP. Thank you for the reply.
Message 10 of 11
(2,509 Views)
