Hi all,
I'm pretty sure that this subject has already been covered.
I would like to manage when the results database is down (server or network)
For that, I'm thinking about offline results processing.
Everything is working if the results processing utility is running on the same machine that TestStand
I'm asking if it's not better to have only one Offline Results Processing Utility which would run on the database server.
Each test station would send offline results files to the server and all files would be processed by the server itself.
What is your comment, your opinion and experience on that?
Thanks in advance
