11-05-2008 01:56 PM
Hi, I don't know if this message should be posted in the Test Stand or LabView forum.
I need to call a LabView VI from within TestStand which will update a station global upon exitting. How do I specify input parameters into my VI and return parameters out?
I'm sure there must be documentaion somewhwre on how to do this but I can't seem to be able to find it.
11-06-2008 08:41 AM
Hello Jules,
The VI Parameter Table of the LabVIEW Module Tab for that particular step is where you can configure parameters to match the connector pane of your VI. Information of this nature can be found in the TestStand help under the following hierarchy:
NI TestStand Environment Reference Help >> TestStand Adapters >> LabVIEW Adapter >> LabVIEW Module Tab
You can also open one of our shipping examples to observe how a VI is called with parameters that match the connector pane in actual practice. These examples are located in the Examples subdirectory of your TestStand installation path.
