NI TestStand
labview gui control using teststand
i am using TestStand for controlling the LabVIEW gui, gui includes the state machine with user interface event handler architecture. For controlling the gui input i have used the TestStand file global's linking with Set and Get property vi in LabVIEW, and for the event structure i have used Val(Sign) property to execute the event in labview. but i am getting problem with some event missing and not synchronizing well between TestStand and my gui.
please help me to resolve this..
Manju G
(4,630 Views)
If i understand correctly you are setting a variable in TestStand.In parallel the LV GUI reads this variable value and does some action.
Does TestStand wait for enough time ( for LV GUI to execute) before it proceeds to the next step where it will set a different value? i.e.
TS - Set a Variable   <----> LV GUI - read this variable and do some action.Finally set one more variable as done.
TS - Is the done variable set? If not keep looping.
TS - once the done variable is set - execute next step.
Please give more details about the synchronisation steps that you have taken.
(4,620 Views)
Hi SunRS,
Thanks for the reply,
       I did same that is, setting a Boolean variable as true after given action completes in LabVIEW. Now i need to wait until the Boolean variable is true in TestStand. Is there any function like wait until Boolean variable = true in TestStand?
(4,614 Views)
Use a while loop step type
while loop step type ( locals.boolvalue==false)
start
Wait 1 sec ( This wait is required else it will be a very tight executed loop)
end
Check out the attached sequence.
Ravi S
(4,604 Views)
Thanks Ravi, It's working
(4,593 Views)
