HI,
I want to specify in the TS CVI Module Call a parameter (panel) and use it by Ref.
I specified in CVI :
"long __declspec(dllexport) TS_HandlePanel(CAObjHandle context, long *TSpanel, long mode, const char *retErr)"
I specified in TS in the CVI Module Call a numeric parameter:
panel
long*
Signed 32-bit integer
by ref
I follow step by step with the CVI debugger and I see that the value of TSpanel is set to some value, however, whet the function ends, the value in TS remains 0.
The value doesn't pass!!
What is wrong with this procedure?
(I know how to transfer the value with the API function TS_PropertySetValNumber, but I wanted to try it this way...)
Thanks for helping
