11-23-2011 10:04 AM
If you just need to do this interactively for debugging purposes, just set a breakpoint in the sequence you only want to run some of the steps in. Then do a normal execution, then when you hit the breakpoint do an interactive execution. You can do interactive executions from a breakpoint in the execution document window.
Hope this helps,
-Doug
09-05-2012 09:39 AM
Ray,
Do you know how to have the SequenceFileLoad callback programatically copy the Main Sequence\Setup to SequenceFilePreInteractive\Setup and Main Sequence\Cleanup to SequenceFilePostInteractive\Cleanup?
This would eliminate having to manually maintain\update the Pre & Post sequences to have the contents from the Main Sequence whenever a developer modifies the Main Sequence Setup & Cleanup.
I have tried a couple of ideas, but have not been successful so far.
Wayne
