03-21-2019 02:58 AM
hello,
I have created a set of shared variables in lvproj, and now I want to load variables into TS, as I search on the internet, I use the step of "Deploy Libaray" to load the lvlib file, but there is no idea of how to use the variable next.
What should I do next?
Thank you
Solved! Go to Solution.
03-22-2019 02:02 AM
You can check this:
https://forums.ni.com/t5/NI-TestStand/Deployment-of-Shared-Variable-Failed/td-p/3801079
You can download example from this knowledgebase -> http://digital.ni.com/public.nsf/allkb/0C91E175667B68E1862571DA0052B13B?OpenDocument
Using LabVIEW with TestStand: http://www.ni.com/pdf/manuals/375070b.pdf
03-24-2019 09:13 PM
Thank U for your help. I have tried your way and get the idea that the step of "Deploy Library" can hold the work of loading the variable of lvproj, and then I can just use the vi with shared variable normally.
10-27-2020 08:45 PM
this links is error. thanks you!
10-28-2020 02:03 AM
how to read/write the shared variable of LabView?
please help me,thank you.
