05-19-2006 02:46 AM
05-19-2006 03:05 AM
You could use the PropertyLoader step for this changing the StartMarker string to point to your new values.
Look at the example in the TestStand\examples\PropertyLoader
Regards
Ray Farmer
05-19-2006 03:53 AM
Hi Farmer
that's what i´am trying to do, but if i have the PropertyLoader step inside the while loop how could i have the StartMarker string as a variable. In other words, if the while loops should runs 50 times, and the the PropertyLoader inside the loops, i should have 50 different StartMarker string and the same for EndMarker string. How could i do that?
05-19-2006 04:06 AM
05-19-2006 04:35 AM
Hi Farmer,
Yes it work perfect
