NI TestStand
how to concatenate a six bytes into a single variable
     how to concatenate six bytes into a single variable.
      For example:
                        a=(Parameters.output[1]<<24)+(Parameters.output[2]<<16)+(Parameters.output[3]<<8)+(Parameters.output[4])
      like this how can i concatenate the 6 bytes........
Thanks in Advance!!!1
(2,889 Views)
if you are using >= TS2010 there  is support of 64Bit integers (int64 and uint64).
with it you are able to store your 6 bytes.
I am using it for saving MAC-Address.
Juergen
--Signature--
NIWeek 2017: Standardized HIL Test Automation With TestStand
NIWeek 2016: Capturing ATE Requirements With Requirements Gateway
Feedback or kudos are welcome
(2,885 Views)
