09-30-2015 12:50 AM
how to acquire the revision of the deployment on the test certificate?
09-30-2015 08:25 AM
Can you clarify what you mean by test certificate? That can have many meanings. For instance when I read it I think you are referring to the report. But I'm not quite sure if that's what you mean.
Also, are you talking about the revision that you set in the TestStand Deployment Utility?
09-30-2015 10:58 AM
good day, I just hit my problem, I have to report on the inspection certificate UUT the version of installed DEPLOY(revision set in the TestStand Deployment Utility)
thanks for the reply
regards
10-01-2015 06:25 AM
regards
10-01-2015 10:55 AM
If you go into Add/Remove Programs and look at the Version column you should see the deployed version.
10-02-2015 05:09 AM
Thanks problem solved
regards
